Subject: Re: Wide Belt Sander
Wide Belt Sander
10/28/24
Robert
I’m eyeing a used Sandingmaster 51” double head with 9,000 hours in auction. Anyone familiar with this make/model? Worth bidding, or should I pass. Thank you.
10/30/24       #2: Wide Belt Sander ...
RODNEY BLACKERBY Member
sanding master is an older brand, probably has air tracking witch is a good thing, If you can get at a good price and needed i would. assume you are buying sight un- seen contact roller damage is one thing to look for. these machines' are fairly simple and most parts are usually available no matter the brand machine, bearings, controls, etc conveyer belt etc. contact rollers can be repaired or re covered.
