Subject: Re: SCM Basic 1 Edgebander overhaul questions
3/9/25
Calgaryguy Member
Im in the process of rebuilding/overhauling a SCM Basic 1 Edgebander, mfg date 1998.
I have a couple of questions:
Glue pot heaters: I may need to replace my glue pot heaters. I'm not quite sure what their voltage is but the machine was converted to 220V 1Ph as some point in the past. They are cylindrical heaters, with 2 of them measuring 16mm dia x 160mm long and one measuring 16x160mm. I've seen generic heaters online for ~30-40 bucks. Suggestions on where to get replacements?
Feed track: The Feed track pads are heavily worn and gouged from almost 30 years of use. The pads are individually riveted to the track and look very much like these
https://www.cncsparetools.com/product/80x30x15mm-Feed-Track-Pads-for-Bi-Matic-Prim
a-Challenge-Edgebanders.html
Suggestions on where to get replacements? Anyone know if there is an upgrade/retrofit to a newer style pad that doesnt require riveting?
Glue pot non-stick coating: The glue pot is in ok shape, but has some scratches in it from people mechanically scraping glue remnants out of it. I see there are services that offer 'glue pot rebuilds' but I've already done 90% of the rebuild (bearings, cleaning, etc). Suggestions on 'refreshing' the non-stick coating either DIY or outsourcing it to a commercial shop (ie: powerder coater, etc etc)
Thanks!
3/9/25       #2: SCM Basic 1 Edgebander overhaul que ...
al
I have that machine since new. Some of my pads on feed track got gouged and I filled the gouges with the edge banding hot melt glue. Replaced the wheels that hold panel down to feed track, bought them from SCM. The rubber on wheels became brittle. Paid around $600 for new wheels about 5 years ago. Those wheels are important for good tracking of edgeband tape. Interested in those heaters you are talking about. I may need them someday and from what I read the glue pot on any edgebander is most expensive part.
3/9/25       #3: SCM Basic 1 Edgebander overhaul que ...
Calgaryguy Member
The wheels are actually in good shape surprisingly. I wonder if they had been replaced already. They do have quite a bit of glue blobs stuck to them.
3/10/25       #4: SCM Basic 1 Edgebander overhaul que ...
Chip Geffre
Greetings!
The heaters that you are referring to are called cartridge heaters. You can find them on Amazon and likely other places when googled. I've bought these for my bander in the past. See link below.
Best Regards!
3/10/25       #5: SCM Basic 1 Edgebander overhaul que ...
Chip Geffre
Sorry bad link...
here is the correct one:
Product Link
3/10/25       #6: SCM Basic 1 Edgebander overhaul que ...
Calgaryguy Member
For the rest of the thread;
I messaged 'RicoCNC' that I linked to in my original post and asked for pricing on their replacement pads.
$6 USD each (I'm in Canada, so about 8.50 Canuckistanian Kopucks ea) with a minimum order of 50.
Now that might be a decent price compared to new parts from SCMi or Biesse, etc for someone with 10's of thousands invested in their shop in a commercial setting - I'm not sure. I'm more of a 'high end' hobbyist or 'one off' small shop (lol) who likes farking with and fixing complicated equipment. At 8.50 each (CAD) an initial order of 50 would be about 2x what I paid for the whole unit to start with. Lol
