Subject: Re: Troubleshooting SCM Edgebander
4/7/18
Armando
Hi Guys,
I have an edgebander
SCM Basic 2 and
Is not heating-up
Temperature stays low.
Thanks...Armando
4/8/18       #2: Troubleshooting SCM Edgebander ...
Dan cook
Sounds like you need a heat station rebuild. You might check underneath in control panel to see if any breakers are tripped.
4/9/18       #3: Troubleshooting SCM Edgebander ...
Rob Young  Member
Website: http://www.cmsrepair.com
Check for a tripped out breaker as Dan suggested. The problem could also be the temperature controller and contacts not closing on it to call for heat. I believe they used Gefran on that model. The problem could also be the contactor that passes the voltage to the heating elements. The heating elements could also be bad but I would doubt all of them are bad so I would suspect it would simply heat up slow if it were a heating element issue.
9/17/20       #6: Troubleshooting SCM Edgebander ...
Robert E Haupt
Have scm edgebander that when using white melamine tape put small teeth like pressure marks in tape after running thru. Any ideas why?
10/26/21       #8: Troubleshooting SCM Edgebander ...
Doug Forester
Website: http://foresterconstructiongroup.com
My SCM edgebanders first trimmer won't return home for the next operation. It will work only on the first piece edgebanded.
Thanks everyone
9/22/22       #12: Troubleshooting SCM Edgebander ...
Bernard
Website: http://mastermillworks.com
I have an scm stefani md edgebander and it is throwing a code 1022 roller conveyor position of joke is not compatible with the stored position!! What's wrong?
9/22/22       #13: Troubleshooting SCM Edgebander ...
Bernard
View higher quality, full size image (4032 X 1816)
2/1/23       #15: Troubleshooting SCM Edgebander ...
Brandon
Hi I have a K230 edgebander and our set temp is 190 and pot is gettting hot but the actual temp is reading zero. Any ideas why the temp isnt climbing?
10/5/23       #18: Troubleshooting SCM Edgebander ...
Mark Armstong
Hi all, we have a SCM ME35 edgebander, it regularly shuts down with the alarm code AL09, We isolate it blow it out to clean it with the compressor and leave it off for a while, it can take up to 30 mins before it will come back on.
What could be causing this and how can i prevent it happening, Thanks.
10/3/24       #25: Troubleshooting SCM Edgebander ...
Luis Rangel Member
I have two alarm codes on Estefani MD edge bander. Who had the same ones and what is it? Alarm Code 0026 (Emergency Button Enabled) and Alarm Code 0028 (Absence Auxiliary Voltage). Thanks in advance.
4/11/25       #27: Troubleshooting SCM Edgebander ...
George
How do I power down my scm me40 ?
7/10/25       #28: Troubleshooting SCM Edgebander ...
Yukon
Website: http://www.yukoncabinet.com
Hi,
I have an SCM edge banding machine that needs maintenance and repair. I'm looking for an experienced technician or engineer who is familiar with this type of machine.
Do you happen to know someone you could recommend?
Thanks in advance!
11/29/25       #30: Troubleshooting SCM Edgebander ...
SaraWil1515 Member
If the temp isn’t climbing at all, start by checking the basics: the heating element, the thermostat/temperature probe, and the relay that sends power to the pot. On older SCM machines a bad relay or a burned-out element is really common. Also make sure the safety micro-switches are engaged — if one is open, the machine won’t allow the pot to heat.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
