Subject: Re: Blum 27" Movento Slides
10/31/25
So I made some drawers that are 27" long and out of Baltic birch which is .585" thick. Attach the locks and insert the slide and it's not going in as far as the normal slides. Almost 3/16" of open space between the back of the drawer and the end of the slide. I checked on some other slides I have as shop drawers which are 21" and they are seated nearly all the way.
The engagement of the pin is there but nowhere near fully like other drawers I've done with Tandems.
Anyone have this issue? Is this how it's suppose to be? I've looked at them and it can't engage any farther into the Movento lock, it's stopped by metal to metal contact. Been using Blum slides forever and this is the first time encountering this. The drawers are spot on 27", by the looks of it a 27 3/16" drawer box would fully engage.
11/2/25       #2: Blum 27" Movento Slides ...
Bruce H
Blum doesn't make a 27" slide, it's 700mm. Drawer box = slide length minus 10mm or in your case 690mm.
11/2/25       #3: Blum 27" Movento Slides ...
From the catalog
MOVENTO
Overall cabinet depth Drawer length
838 (33") 762 (30") 769.7620S
762 (30") 686 (27") 769.6860S
686 (27") 610 (24") 769.6100S
610 (24") 533 (21") 769.5330S
533 (21") 457 (18") 769.4570S
Wood screw for installation 606N or 606P
System screw for installation 662.1150.HG
11/2/25       #4: Blum 27" Movento Slides ...
Well that didn't work well
View higher quality, full size image (1479 X 446)
11/5/25       #5: Blum 27" Movento Slides ...
I use salice progressa plus never have this issue and they are better slides anyhow
11/5/25       #6: Blum 27" Movento Slides ...
I've never had this issue either which is why I'm asking. Saying use another slide isn't helpful. Maybe it's possible there is and American and a European version of the slide and I was sent the metric version instead of the imperial slide.
I'm going to have to ask my supplier about this.
11/9/25       #7: Blum 27" Movento Slides ...
Craig Caughlan  Member
Website: https://www.instagram.com/craigcaughlan/
I've installed a lot of Movento metric slides, with and without the TipOn accessory (push to open) and have not encountered this.
11/9/25       #8: Blum 27" Movento Slides ...
All the 21"ers I've used were correct. So far it's just these 27" ones. The drawers are installed and everything seems to be working OK. The locks hold things tight and the rear pins are in the holes far enough to do their job. Still irks me that there is that 1/8" space back there when it should be much less.
11/9/25       #9: Blum 27" Movento Slides ...
All moventos come from Europe at the moment.
11/16/25       #10: Blum 27" Movento Slides ...
Keith Farr
Are you using a thicker front rail/header on the front of the drawer? Thicker front rail would leave drawer same length but push clip back
11/16/25       #11: Blum 27" Movento Slides ...
Nope, Baltic Birch that measures .585". Same stuff I've been using since forever.
1/7/26       #12: Blum 27" Movento Slides ...
Gerben Member
For a standard 550mm movento i make the drawer box at 21.25" but you do 21" ??
For a 700mm movento i make the box at 690 mm which converts to 27.16" so then doesn't that make perfect sense that yours is 3/16 too short
All blum sizes you gotta subtract 10mm for the drawer length
I don't think there is such thing as a slide that fits a 27" box
1/7/26       #13: Blum 27" Movento Slides ...
This is the list from the official Blum PDF for the Movento Slides.
View higher quality, full size image (1256 X 396)
1/7/26       #14: Blum 27" Movento Slides ...
Guess I posted that already. I'll have to look at my order sheet to see what was sent
1/7/26       #15: Blum 27" Movento Slides ...
Order that I placed said ordered the 769.6860S which is for the 27"
686mm/25.4mm=27.007"
View higher quality, full size image (1095 X 285)
1/7/26       #16: Blum 27" Movento Slides ...
Gerben Member
My movento slides start with 766, but that's in Canada maybe yours are different?
1/7/26       #17: Blum 27" Movento Slides ...
I'm sure. We use Imperial Measurements.
1/7/26       #18: Blum 27" Movento Slides ...
Gerben Member
Ok makes sense, but i would just add a 3/16 block on the back of the drawer with a hole for the pins, it'll solve the issue for now
1/7/26       #19: Blum 27" Movento Slides ...
The rear pin is inside the hole enough to secure the drawer. I was going to router a spot in the front so the lock would be forward another 1/8" as a solution. That way I could use 1/2" screws to secure the locks instead of the 5/8" I usually use. Same result, different solutions.
I wish I still had the box they came in so I could see the actual number. 690 would be my guess.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
