Subject: Re: Pivot Hinges
Pivot Hinges
1/20/26
Robert
I’m pricing dressing room/closet cabinetry and the architect has specified offset pivot hinges. Has anyone had much experience with these? The doors will be 1-1/8” rift white oak mdf core, roughly 20” wide x 7’-6” high. Obviously I’m concerned with weight and straightness of door with only hinge on top and bottom. I will try to convince them to go with Blum hinges. Any thoughts appreciated. Thank you.
1/21/26       #2: Pivot Hinges ...
Alex_Zhang Member
You are right to be concerned, Robert, but maybe not about the weight.
High-quality offset pivots (like Rixson) actually handle heavy loads better than cup hinges because the weight is transferred vertically to the floor, rather than shearing off the cabinet side panel. The 1-1/8" MDF core is heavy, but the pivot hardware won't mind.
The real killer is the bowing (straightness). At 7'-6" (90") tall, supported only at the absolute top and bottom, you have zero control over the center of the door. Even with a stable MDF core, if that Rift Oak veneer pulls the door into a slight bow over time, you cannot adjust it out. With Blum hinges, you can simply tweak the depth on the middle hinge to pull the door straight.
Advice for the Architect: If they absolutely insist on the pivot aesthetic, tell them it is mandatory to install heavy-duty door straighteners (tension bars) routed into the back of the door. You need that mechanical insurance policy since you don't have a middle hinge to do the job.
1/22/26       #3: Pivot Hinges ...
Rixson and others offer intermediate hinges. Just Google it.
1/24/26       #4: Pivot Hinges ...
This door has a closer/floor pivot recess into the floor and two intermediate hinges. Last I saw, it had been up over 12 years, no problems.
We got into big pivot doors for a few 6' x 10' doors and similar sizes. Only two points, top bearing carries almost weight, the lower hinge/bearing do all the work. 12" - 18" of width of the door would swing to the outside when the other segment swung in.
I could only picture anxious children greeting guests and their fingers getting worse than crushed by the physics on display. One of the site carpenters referred to it as a "cat-killer", citing the animals propensity for last minute charges at a closing door.
View higher quality, full size image (768 X 1024)
2/24/26       #5: Pivot Hinges ...
Daniel French Member
Looking at those 7'6" doors, I keep thinking about how much client communication matters on details like this. The hardware choice changes not just function but long-term callbacks. I’ve found that even small presentation tweaks can help close upgrades. Funny enough, similar thinking applies in https://onstipe.com/blog/how-to-drive-event-registrations-through-call-driven-soci
al-ads/ for event registrations—framing drives response.
    • American Fabric Filter Co.
    • Sandman Products
    • The Millwork Studio
