Subject: Re: Floating shelves
Floating shelves
2/19/26
Travis
We seem to be doing these more and more and have used several different brackets and supports, none of which I've been completely happy with. They always seem to end up feeling "spongy" to me, or aren't long enough to support the shelf depth, or won't hold level, etc. I'm playing with the idea of just using some type or rod or huge bolts or something driven into the studs. Do you have a system or method you've settled on that you'd like to share? FYI our shelves are always torsion boxes, and can sometimes be supported on one end. TIA
2/19/26       #2: Floating shelves ...
Have you tried these? As long as you hit studs they are pretty sturdy.
Floating Shelf Bracket
2/20/26       #3: Floating shelves ...
Travis
Leo-thanks for the response. I have used those, and still am as they do work better than others I've tried. But I have mostly the same issues with them. Installed over drywall, they are spongy. I have cut out the sheetrock and installed directly to studs but that is a mess and still flexes somewhat. Also the longer lengths I often need are kinda pricey.
2/20/26       #4: Floating shelves ...
Can't really disagree with anything you said. The secret is not to crank the screws so hard you crush the drywall behind them. Once you do that it looses the stiffness. And they aren't the cheapest or the easiest to implement.
If you could find studs and put something like rebar into them and keep it straight and level that would be stiffer. But I'll bet it's tough to find studs right where you need them and to drill the holes perfectly the 1st time around.
