Subject: Re: Critique my assembly fastener scheme
4/15/26
Gene Davis Member
We site-build residential cabinetry from CNC-cut KD parts and use eCabinets software. Joinery is what eCabs calls lock dado, which is blind dado with intermittent gaps, and at the gaps, ZipR screws are used for fixing. The image attached here shows a typical wall box, 40" h. x 38" w. x 14" d. You can see where and how frequent the screws are placed. We use #6 x 2" size screws. Sides to top and deck are two screws at top and two at deck. Sides and deck and top to captured 3/4" back are spaced at about 12" as can be seen. Is this adequate and if not, where should there be more?
View higher quality, full size image (851 X 877)
4/15/26       #2: Critique my assembly fastener schem ...
Jr Lee  Member
Website: http://www.leecabinets.com
I built my cabs that way except only 12" deep. I did not use any glue and had 3 screws on the sides, top and deck.Never had a problem. How is the lock dato working out? I never tried it but thought it worth trying.
Jr
4/15/26       #3: Critique my assembly fastener schem ...
Gene Davis Member
Thanks for looking
Lock dado works well. I asked this because while I had done dozens of kitchens using eCabs and the lock dado scheme, I changed laptops and foolishly backed up incorrectly so I lost all my seed cabs and am starting over.
I'd forgotten how many screws I'd been doing for the wall cabs at the sides for side-to-top and side-to-deck. I'll add one at center by changing the length between in the spec dialog.
Below is a view of the joint for 4" stretcher to side, same as front edge of a split-top base. One tenon, two screws.
Made the change in wall cabs depth from 12 to 14 after researching trends and experiencing doors that won't close when modern plates and dishes are stored. Doesn't add much cost but makes for a custom feel and experience.
View higher quality, full size image (969 X 690)
4/20/26       #4: Critique my assembly fastener schem ...
Stu
Gene, I could be wrong, but you should check out the AWI standards for KD cabinets, I believe they spec a minimum of a #8 screw. Along with that, the distance of the screw hole to the edge of the workpiece needs to be greater than 5/8, IMHO. We often use eCabS for our boxes and in practice, even with a properly set predrill, our installers would end up splitting the taped edge because the screw was too close. We moved it back to >7/8" to solve this, and we can make stretchers as narrow as 4" and still get a tenon in the middle. As far as general spacing, I would also look to the AWI standards for doweling KD cabinets, as the dowel positions would essentially mock the screw positions. I will typically design the fasteners about 12" apart, unless there are other prioritizing factors, like intermediary partitions or dividers. Not gospel, just what I do.
