Subject: Re: Old Blum hinge
Old Blum hinge
8/5/16
mark
Does anyone know a source for the old-style Blum compact face frame hinges that have a reverse boring pattern? The model is 30.310-11.02. It hinges on the straight side of the door cup. Replacements that I've found look the same except that they hinge on the semi-circle side of the door cup, which require patching the old dowel holes. Any ideas? Shy of new doors...
8/6/16       #2: Old Blum hinge ...
Wow! That is an oldie. Did you try contacting Blum directly. They would probably have some or know which of their distributors or kitchen manufacturers had ordered this in the past.
3/16/25       #3: Old Blum hinge ...
sherwin dubren
I purchased a replacement for a 30.310-11.02 Blum Cabinet Hinge from Amazon. They claimed it was a simple swap using the existing face plates on the cabinet. However, when the door is positioned properly, it will not close completely with a gap of about 1 or 2 inches. Amazon says I should be able to utilize the existing face plates that the hinge hooks onto. The brand of the hinge is Aituzero, but I cannot find any support from them. Blum has discontinued this hinge, so they probably cannot help me. I tried adjusting the positions of the plates, but that did not help. Any other ideas?
5/11/26       #5: Old Blum hinge ...
Eric
For the replacement hinges I purchased, a small adjustment to the screw and mechanism that connects to the old, original cabinet connection side of the hinge will hold the hinge side of the door further from (or closer to) the cabinet so the non-hinged side closes more completely rather than hanging slightly open.
With the door open 90 degrees (or a bit more) support it from below and loosen the screw on the connecting arm until you can slide it on its rails. I pushed the door a bit to the right until about half the rails were exposed and retightened. Then did the same to the other hinge and that solved my problem.
Loosen only slightly so the connecting arm does not come apart completely, Otherwise you may have to reassemble.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
