Racked case clamp?
4/29/15
Stephen Patterson
Has anyone ever heard of a case clamp racking? We're going to be purchasing one, and became aware of a case clamp that the owner has pushed into the corner because he cannot get it to clamp the boxes square. My instinct tells me that it is not the clamp at all, but wanted to hear other's input.
4/29/15       #2: Racked case clamp? ...
Could be out depending on design. Good ones are very robust welded frames. Should be easy to check.
4/30/15       #3: Racked case clamp? ...
chip geffre Member
Stephen-I am willing to bet the clamp can be adjusted. Most clamps have a rigid frame but also have a method of calibration.
The unit I now have has rails on the bottom which are adjustable to fine tune the squaring.
We also installed a vertical platen (1" MDF, with laminate on 2 sides which was also shimmable to square.
My guess is the "out of square" unit was not leveled and adjusted properly before use.
Best Regards, Chip
5/3/15       #4: Racked case clamp? ...
bob
don't know manuf./ model you have, but we have a ritter 525 and there are adjustments, there could be a lot of reasons why he could not square his cabinets, ie, back not cut square/ too small/ parts not square, etc it only clamps the parts you give it, good in/good out
