Panel Genie
Biesse Rover 24 Slot Guard Help
3/3/16
John Earp
I am having a problem with one of my spindle head settings i changed out two bits in the revolver and noticed one of the carriers could be out of alignment so i switched it with one that was not in use, I have unrung and equipped all the right tools in the appropriate slots and they seem to be working fine but as soon as I need to change tools the revolver does not move and I have an error message -
PLC 92757> slot guard cylinder 1 up is missing (1 , 47)
PLC 9007> Slot reset Required
any help would be amazing is it a sensor or a setting that is the problem, Thank You John
3/4/16       #2: Biesse Rover 24 Slot Guard Help ...
Kirk Walby
It sounds like your spindle is not going all the way up. Have pushed or clicked on the "slot reset" button" ? If so, and you are still getting the error, then maybe your spindle is all the way up but the machine cannot detect it. Look for a proximity sensor near the top of your Z axis.
When the spindle is in the up position, this sensor should be lit up. There might be some crud between whatever metal the sensor is supposed to detect and the actual sensor. To check if the sensor is working, take any metal object and touch or hold it close to the end of the sensor. If it lights up then you know the sensor is ok.
1/19/19       #4: Biesse Rover 24 Slot Guard Help ...
John Earp
Website: http://mountainhomecabinetcompany.com
Now it works fine changing 2 tools and milling but then when it changes to tool #1 it rotates and drops down to the
preliminary height, keeps spinning, but
will not lower to milling height.
same error message but ends: (1, in 64)
Thank You for your help! John
    Lamello
