Unique roll top desk
4/12/16
This customer!'s husband made this roll top desk for his son like 30 years ago, got pissed at him and never finished it. The wife now wants us to finish it, so she can give us to her daughter.
I have never seen a tambour roll top made this way. He drilled small holes into each of the slats and ran a steel cable through it.
I'm not familiar with making roll tops, let alone how to make this style work
Is it the sure weight of the roll top that will make it slide open? He has loops of steel cable at the ends (not sure what he was thinking
Do any of you have any thoughts as to why someone woukd do this and or what the intent is?
Thx!
4/12/16       #2: Unique roll top desk ...
Steve Member
Follow link below...
Tambour Door Sets
4/12/16       #3: Unique roll top desk ...
Leo G
I made it the same way for a bathroom garage cabinet.
Just used a corebox bit and a beading bit.
View larger image
4/12/16       #4: Unique roll top desk ...
Leo G
Front view
View larger image
4/12/16       #5: Unique roll top desk ...
I don't understand your question about it opening. "Is it the sure weight of the roll top that will make it slide open?"
Every tambour has to be lifted to get it open. Well except for the horizontal ones. He just used cables to hold the slats together instead of gluing on canvas. The loops of cable just haven't been trimmed. You do have to have either crimp fittings, or set screw collars tightened to the cable to keep all the slats in one unit. You have to counterbore the first slat so this connector is in the wood. That lets it sit tight on the desk top.
4/13/16       #6: Unique roll top desk ...
D Brown
Usually the weight of the tambour going down the back side will support and hold
it in place.
4/15/16       #7: Unique roll top desk ...
Keith Newton
You can also use a loop in the end of the wires, then a spring between pairs to keep them tight.
