Holz Her glue for HPL
6/11/16
Eric Smith
We have a new HolzHer which uses the cartridges.
We're using Dorus HKP 25 but having trouble with the laminate strips sticking. What is the best glue for this machine when we have to use laminate edging? Without the seperate step of priming the back of the panels before ripping?
Thank you for your help.
6/11/16       #2: Holz Her glue for HPL ...
You will be a lot better off priming! Cheap insurance. Laminate sometimes has a release still on it.
6/11/16       #3: Holz Her glue for HPL ...
cabinetmaker
Yes, Dorus and Jowat both make primer, or you can use contact cement as the sealer in a pinch. I would highly advise against hpl directly applied without.
6/14/16       #4: Holz Her glue for HPL ...
Jay Member
HKP-25 best glue, still need to prime. I would use the dorus primer with the dorus glue.
