Radius fishtank cabinetry
6/19/16
I have a radius fish tank job I will be bidding out but I'm very nervous about finding the radius of the convex tank. The tank is HUGE. probably 8 ft long 36" high, not sure how deep yet. I saw it when i wss working for another company and a lady im doing work for now...its her mom! Small world!
How do you guys propose i get the radius and i have no clue where they're going to put the fish.
Also, would you guys suggest i pick up the tank and bring it to my shop so i have it there or make a cardboard template if possible of the entire shape
6/20/16       #2: Radius fishtank cabinetry ...
pat gilbert
I have used this method a number of times, it works great.
this is what you are looking for
6/20/16       #3: Radius fishtank cabinetry ...
Adam Spees
Way to complicated.
Boat builders have neither the brains nor the time to do mathematics. In reality when scribing cabinets in boats with multiple curved and straight surfaces math is impractical.
The accurate way to do this is called spiling.
The way I like to do it is with a piece of cardboard and a stick. You rough cut cardboard within an inch of the object.
The math is also useless for not circle shapes.
Take a straight stick about 1" x 1" x 12".
Cut one end at 45 degrees. Butt the point of the stick up to the shape. Take a pencil and draw a line atleast halfway up the stick and continue across the butt end. You should have an L. Do multiple marks until you can accurately connect the dots. This technique works on straight, round and curved shapes.
Now take your template and you can reverse the marks on to a piece of ply and generate a very accurate shape.
You can take a thin batten 1/2" x 1/2" of straight grained redwood or cedar and connect the dots with it.
Its very easy. This is how you shape bulkheads for boats.
6/20/16       #4: Radius fishtank cabinetry ...
Adam Spees
Make sure you always use the same edge of the stick for marking and transferring. The 45 degree cut makes the stick assymetrical.
6/20/16       #5: Radius fishtank cabinetry ...
John Costin
If you know:
a) that the arc is a constant curve (i.e., circular and not elliptical);
b) the length of the arc; and
c) the height of the arc (what you call "depth" in your post),
then you can calculate the exact radius using a CAD program or a circular arc calculator you can easily find online.
With an exact radius you can swing a perfect template or have one CNC cut. The latter is extremely useful for very large radii -- every time I have to swing a 25 foot radius I find that I've just cut my last 25 foot stick ;8>).
Spiling is a great technique for irregular curves, but in this case math (along with a computer) is your friend.
John Costin
Veneer Services Unlimited
vsu@gwi.net
(207)985-7221
Custom Veneered Components for the Woodworking Industry
6/20/16       #6: Radius fishtank cabinetry ...
My initial thought, because the fishtank is already installed, is to find the center of the width (left to right) take a framing square at the center, measure the height of the chord, then transfer that into autocad
Thx for everyones suggestions
6/20/16       #7: Radius fishtank cabinetry ...
pat gilbert
Mike that is the same thing without the math.
Is this what you mean? see the picture
See the link at tick stick:
The way I and counter-top guys do it when necessary is to make a template by gluing 2" wide strips of 1/8" luan together with hot melt glue.
Tick Stick
6/20/16       #8: Radius fishtank cabinetry ...
I would use the math method as in the Knowledge Base. There are also online calculators. You need the chord length and the altitude at the center point in the length of the chord for the calculators. There are also several good ones at the App store.
Once you have a good radius, put a router on a stick and swing the radius on some scrap 1/4" ply or similar. Take this out to the tank to insure 1. that the tanks a true radius, and 2. that your arc fits properly. Use the router on a stick to cut frame parts and such at the various radii. This will keep things concentric and true.
The radii in the attached photos were determined by interior measurements of chord and altitude, and by exterior measurements of chord and altitude at the ends of the chord (straight edge). Everything fit perfectly.
6/20/16       #9: Radius fishtank cabinetry ...
pat gilbert
I think Dave is starting to get the hang of this stuff?
6/20/16       #10: Radius fishtank cabinetry ...
May seem obvious but dont you have access to the top of the tank? Cant you just have the owner remove any hardware/covers/filters, and lay a sheet of cardboard over the top and trace the top of the tank? If you were worried about deviation from top to bottom you could cut an external template from the traced patter and check it against the base and adjust accordingly?
6/20/16       #11: Radius fishtank cabinetry ...
Its been a while but from what I remember, there's a custom radius cap at the top and at the base of the tank, hence why i think it would be very difficult to make a template...time will tell..,
6/20/16       #12: Radius fishtank cabinetry ...
Kevin Jenness
David is right on. Use the math or have your CAD do the math and then check it onsite. If the tank is not a true radial curve use the spiling technique to get as close as necessary.
6/21/16       #13: Radius fishtank cabinetry ...
Adam Spees
Pat,
Yes the tick method is spiling.
I have seen people use different shaped sticks or the tick mark. I find my way of following the side and the end is simpler and gives a perfect way to realign the stick.
You are all assuming you can actually get accurate measurements and then do the math.
I'm assuming that you can't and spiling is very accurate if done correctly.
Do the math, make a template on the cnc then when it doesn't fit, you can use it as a spiling template.
6/21/16       #14: Radius fishtank cabinetry ...
I have tried the tick stick method and found it to be a PIA, I prefer using the strips of luan for irregular shapes.
With circular walls which are never concentric the method I linked works great.
If you have a lot of this to do then you can go with a laser template.
Well we came up with 4 ways to skin a cat...
Mike will go with what he was thinking in the 1st place and it will work great.
    Lamello
