Circle / radius top wall cabinets
7/29/16
Mark Member
I've been asked to quote 4 cabinets similar to the circle top cabinets in the photo. Each box is approx 17"w x 36"h x 12" deep.
I've made some radius jamb extension etc but with these I'm concerned about:
A. Spring back that occurs with a glued up lamination.
B. A seamless transition at the straight / radius transition.
C. Other potential minefields as I can't put a fixed shelf / divider at the very top of the straight portion of the cabinet.
The doors are a non issue for me. I'm concerned about product and method for a structurally sound cabinet box.
Tips, tricks, divine revelations are all welcomed.
Thanks!
7/29/16       #2: Circle / radius top wall cabinets ...
Leo G
Look at the Kerfkore site.
Kerfkore
7/29/16       #3: Circle / radius top wall cabinets ...
Build a jig for gluing it up. You could use a vacuum bag as well.
I would put the seam at the top.
Use plastic resin glue to minimize spring back.
I used bending poplar and 1/8" plywood at face.
7/30/16       #4: Circle / radius top wall cabinets ...
Snaglpuss
1/8 bending poplar ply lamination for the top. Minimal to no springback, paints nice too.
7/30/16       #5: Circle / radius top wall cabinets ...
Dustin orth
Use a 3/4 back panel and I'll 2nd the kerfkore.
7/30/16       #6: Circle / radius top wall cabinets ...
Bruce H
Out of curiosity, what would four cabinets similar to those be worth? I have curved cabinets across the front (radius doors) but never the top. I didn't add enough money to cover the pain endured building them. Next time I will.
7/30/16       #7: Circle / radius top wall cabinets ...
Figure out for square and multiply by 5
8/1/16       #8: Circle / radius top wall cabinets ...
Rick W
You can make the sides straight and join them to curved tops made from fiber or plywood tubes. You can get fiber cylinders and other shapes from Shapes Unlimited and curved plywood cylinders and half-rounds from Roberts Plywood.
Rick W
8/1/16       #9: Circle / radius top wall cabinets ...
Mark Member
Thank-you for all the helpful advice!
Proposal going in this afternoon..
8/1/16       #10: Circle / radius top wall cabinets ...
So what method will you be using?
8/1/16       #11: Circle / radius top wall cabinets ...
door shop guy
I always just made a form and used two layers of bender board and veneered, trim to size then join to ply bulkheads.
Now they have Kerfcore but i have not tried it. Do you just fill the voids with hot glue to get it to hold its form?
8/1/16       #12: Circle / radius top wall cabinets ...
In this case you would make a form and then either strap or vacuum bag another veneer onto the kerfed side. After the glue dries it will maintain the shape. Use a veneer to cover the front edge of the core and then paint.
8/1/16       #13: Circle / radius top wall cabinets ...
FWIW I like the Roberts plywood idea. Making jigs is a PIA.
As the famous philosopher said get er done.
8/2/16       #14: Circle / radius top wall cabinets ...
Bob Harkleroad
That's all well and good if your radius is a standard size that's available from the pre-formed guys. Otherwise it's forms and kerfcore for us.
8/2/16       #15: Circle / radius top wall cabinets ...
Yup, same thing here. Why struggle?
View larger image
