HPL on an edgebander
8/30/16
Good morning.
I have a Biesse Stream.
A client of ours requires HPL strips as edge banding.
We've been able to sort out the top/bottom trimming but can't seem to get the end trimming clean, they are chipped.
PVC works fine, so I assume the blades are OK, but I can't imagine what else it could be.
Any ideas or advice welcome.
8/30/16       #3: HPL on an edgebander ...
Carm
Are you running an hi-atb blades? And what is your tooth count?
8/31/16       #4: HPL on an edgebander ...
Seems to be atp blades.
20 teeth.
Don't know how old, I bought the machine used.
8/31/16       #5: HPL on an edgebander ...
Carm
I think that a negative rake tooth would be more ideal for hpl as its cutting against the face as the spindle drops. Maybe give one of the higher end blade manufacturers a call a they should be able to answer some blade application questions. Then I would buy an extra set and have your others sharpened.
9/1/16       #6: HPL on an edgebander ...
Larry Member
Sharpen blades. Higher tooth count would help.
9/16/16       #7: HPL on an edgebander ...
Or the trim blades could be installed so the cutting is done with the front of the tooth, not the back.........
9/16/16       #8: HPL on an edgebander ...
Al
Umm, are you saying the blades were on backwards ?
