Drawer Glue and Clamping
1/13/17
Ian Young
Website: http://iandccraftsmanship.com
Using a pneumatic drawer clamp, how much time is efficient enough for the drawer to be taken out of the clamp? Our drawers are typically 1/2" prefinished maple plywood doweled. We use tight bond 1 for the dowels, roo glue for a little extra hold on the edges and hot glue on the bottom. We will be doing all the assembly, including drilling for clips and installing them while in the clamp before we remove the pressure.
1/17/17       #2: Drawer Glue and Clamping ...
Zack
I would believe that you should be able to take the drawer out of the clamp after hot melting and installing hardware as long as you are gentle on the joints. You only need 2-3 minutes for the glue to be able to work.
The dowel should expand enough and the glue should set enough for the hot-melt to keep the drawer joints firm and in place.
There are also variables like humidity and heat to take into consideration. Best thing to do is just test and see what works best for you.
1/17/17       #3: Drawer Glue and Clamping ...
I 2nd Zach. Dowels seize in less than 3 minutes, not cured but can be handled at that point. We also use original Tite Bond, melamine glue & hot melt but melamine boxes, usually. Clamp is a Doucet, works really well. Give it a test. Hot weather makes for faster.
