Thick door pocket/flipper door hardware
4/16/17
Matt Calnen
Hello, I just got asked by a very good customer to modify her French armoire into a TV cabinet. The frame of the door is one inch thick and it has an applied molding that sticks out Past the face of the door 1/2" to 5/8". I was wondering if there was a pocket or flipper door hardware that would accommodate this much thickness? I normally use accuride flipper door hardware but didn't see any that would handle this thickness. I can grind the molding down with a wide belt but don't want to go that route if possible. Or, is there a way to use a taller mounting plate to make it work? Thanks in advance
4/16/17       #2: Thick door pocket/flipper door hard ...
david zaret Member
that's a pretty thick door. the accuride 1432 with the 40mm hinges gives you about 1 1/4" i believe... but 1 1/2"+ is tough. a year or so ago i faced a similar issue, but my doors were on the edge of able to be accommodated by the 1432. sounds as though yours are not.
is there any way to "move the moulding" to the fixed frame and have the "panel" of the door be the only operational part?
good luck.
-- dz
4/17/17       #3: Thick door pocket/flipper door hard ...
Dan
Hafele Hawa Concepta can do almost 2" thick but doors must be minimum height of 49". Pretty much everything else is 1 1/4" max thickness using 40 mm cup hinge.
4/17/17       #4: Thick door pocket/flipper door hard ...
Scott in NC
How about rabbeting the back edge of the hinge stile? I would try that before messing with the moulding.
4/17/17       #5: Thick door pocket/flipper door hard ...
Matt Calnen
I was thinking about taking a router and recessing where the hinge mounts. I didn't know if that would work or not. The door frame is 1 1/4 and the molding 1/2"ish beyond that. If I routered in one half inch it might just clear. Will that affect anything else? Will the rest of the hardware clear?
4/17/17       #6: Thick door pocket/flipper door hard ...
Dave L
Accuride 1321?
