Festool Edge Bander KA 65
4/20/17
Chris
hi,
anybody on here got the Festool Edge Bander KA65, i have a question can i edge band 3/8 thick material with it? on there website it says 3/4 to 2 9/16 thick material only
thanks
4/20/17       #2: Festool Edge Bander KA 65 ...
Harold
Are you talking about the tape thickness or the tape height?
4/20/17       #3: Festool Edge Bander KA 65 ...
Chris
I'm talking about the thickness of the panel/material I wanna edge band is 3/8" thick, festool support told me 3/4" is the minimum thicknesses of the panel I can edge band
4/20/17       #4: Festool Edge Bander KA 65 ...
Harold morantz
Did you already buy the machine? Check with Virutex and Adwood Corp. they both make similar machines with probably less plastic parts. Do you need to do curves and how thick will the tape be? If you only need straight panels banded, there are small table top ganders with glue pots that are available here in Florida that are under 2k and you can lower the indeed fence to whatever height you need.alit of small shops but them.
4/20/17       #5: Festool Edge Bander KA 65 ...
Harold morantz
I think it's called Makshwa. You can check on eBay for small glue pot banders.
4/21/17       #6: Festool Edge Bander KA 65 ...
Chris
thanks i gonna check them out
4/23/17       #7: Festool Edge Bander KA 65 ...
Derrek
I have one , ill check tomorrow. The Festool is 10X better than the other glue pot portable banders out there. I had a virutex and it was a model T and the Festool is. Lexus
