Melamine edges
6/13/17
Caradd Member
We don't use much melamine in our shop.
Is it necessary to tape raw edges to help resist swelling.
The current project is simple 36" x 48" melamine panels set into a steel fabricated frame to act as office cubical dividers.
Beyond that project I always wonder if we should be taping the bottom edge of base cabinets. Does it make a difference what surface the edge will be in contact with (ie ceramic/stone as opposed to carpet/wood). Thanks for your input.
6/14/17       #2: Melamine edges ...
Paul Miller
I would not edge the edges being set into a metal frame unless I thought moisture was going to be a problem.
As for the sides of base cabinets, we use leg levelers and we do not have our sides going to the floor if these sides are melamine or any particle board, even if they are on carpet. We use a separate toe kick made from plywood with a laminate face to match the melamine.
6/16/17       #3: Melamine edges ...
The floors will probably be washed. That will lead to the board soaking up water and looking like cr@p. Not sure that taped edges will be much better.
