Helixhead
8/18/17
Kevin Member
Anyone had experience with the HelixHead spiral cutterhead on a planer or jointer? Wondering how they compare to byrd or others. Thanks
8/18/17       #2: Helixhead ...
Guy Knight
no idea on the helix head but i do love the byrd heads i for the first time had to buy new inserts after 8 years of heavy use
8/18/17       #3: Helixhead ...
I put the Byrd head on my 15 planer and it made small but noticeable grooves in hard wood. Byrd took it back and i then installed a regular helix head and the problem went away. With the 4 sides to the cutter i also got years out of the original set but i guess that depends on how much production you do. Well worth it, I'll do it again in a heart beat.
8/18/17       #4: Helixhead ...
dub
I have a 20" Byrd Head in my planer and a 16" Helixhead from Hermance in my Oliver jointer. With sharp inserts, both give a very good finish (still needs sanded). However, I originally tried to get a Byrd head for my jointer and gave up after waiting over 7 months for Byrd to make it. I got many excuses about machine problems, weather, etc. Hermance was a little more $, but the service and product were both very good.
8/19/17       #5: Helixhead ...
Chris
Got grizzly 12" jointer and 20" planer...both with their standard helical heads. Total game changer...can't imagine the Byrd or fielder or whatever is that much better. We get slight tear out on figured Eucalypus. Other than that it's been fab
8/19/17       #6: Helixhead ...
Mike Fuson
I'm not even sure I now the specific difference between a Byrd and a helical, but about two weeks ago I put a Byrd spiral on my 15" planer and can't believe the difference from my old 3 blade cutterhead. Much much quieter and a superior cut. I had to wait a month and a half for them to make it, I was about to give up on them.
8/20/17       #7: Helixhead ...
dustin orth
I have Byrd, Charles GG Schmidt and Titan Knife Works spiral cutterheads for my molder and my planer has a Cantek spiral. Not sure if there is one better than the others. I have had a planer in the past with a Grizzly spiral and that is what started me using them on anything that could have one since my main product material is Knotty Alder. Very hard to keep to the knots from blowing apart with anything straight knife.
9/7/17       #9: Helixhead ...
Aaron
I have one on my old 18" powermatic and one for my vintage Oliver 12". I absolutely love them. The only other ones that I have used are grizzly and powermatic. The powermatic is on a 8" jointer and seems to be good quality too, but the grizzly is set with no shear angle and you can tell the difference with higher noise and inferior cut quality. Honestly, the other reason that I like the helix head is because I was able to get it custom made and the company that makes them is reputable and has been around for a long time.... service is important, and don't forget to ask about the inserts. Not all inserts are the same quality. If you have multiple heads from different manufacturers they may not be interchangeable between brands.
