Confirmat Screw Stainless Steel
10/19/17
Manfred Warnecke
Website: http://www.hollywoodwoodwork.com
Hello fellow woodworkers,
anybody out there ever used CONFIRMAT SCREWS in STAINLESS STEEL?
I need to find a supplier and it should not be out of Chinese Production.
Thank you very much for your help
10/21/17       #2: Confirmat Screw Stainless Steel ...
What material are you using in an environment that needs stainless fasteners but cant use a different fastener type? It would seem you wouldnt be using PB core. Wouldnt a different type of readily available stainless fastener work? (may still be chinese)
10/23/17       #3: Confirmat Screw Stainless Steel ...
Manfred Warnecke
Well, the cabinets are outdoor kitchens made from Starboard. Sorry, I should've mentioned that.
10/23/17       #4: Confirmat Screw Stainless Steel ...
That's what I assumed. You have the ability to use many different readily available stainless fasteners with Starboard. If you must use confirmats you may have to order them from Asia. I've not seen stainless as they are generally a ply/pb core fastener.
    Lamello
