Panel Genie
Closet rod layout
11/20/17
al
I've done closets in the past but am trying to nail these dimensions down so not to go through this again. How much space is normal from top of closet rod to bottom of shelf that is above it? It
looks to me if I use the brackets with 2 pins that fit into system holes and use oval rod it only leaves 1-1/4" from top of rod to bottom of shelf. If I go to next system hole distance is too much
and this will also make less space for 2nd rod from floor. Is there a standard for this? Maybe round pole works better? If so what diameter do most use?
Thanks,
Al
11/20/17       #2: Closet rod layout ...
Leo G
Bottom of the shelf should be 67 1/2" and the top of the rod should be 1 1/2" below that.
11/21/17       #3: Closet rod layout ...
Todd
Stud for the shelf goes in the top hole, then skip a hole, then the pins on the rod cup go in the next 2 holes down.
11/21/17       #4: Closet rod layout ...
al
Thank you both. I'm looking for double pole and Todd has it the way I thought it should be.
11/21/17       #5: Closet rod layout ...
al
Todd,
What distance do you use for hole distance front edge to back row of holes? I'm setting it for drawer slides but I know they have different accessories and maybe there is common distance so everything works. Center of front holes to center of back row holes would be helpful also.
11/21/17       #6: Closet rod layout ...
Todd
Hi,
I don't have a good answer for that, our slide holes are drilled independant of the system holes.
On a 356 panel, our system holes are 82 in from each edge. With this, the top back cams are accessible with the hanging brackets in place, and the front holes position the closet rod about 10 3/4" off of the back wall. Slides use separate holes.
11/21/17       #7: Closet rod layout ...
Bruce H
I make my closet panels an even module of 32mm in depth plus 5mm. This makes the distance between the holes on an even 32mm. My decks are end panel depth less 5mm. The overall height of my end panels are and even module of 32mm. The back hole is stepped in 96mm and the front hole is stepped back 37mm. From a twist lock pin to the closet rod is 96mm. My closet rods center 320mm from the back of the end panel. If you leave only 1 1/2" over the rod to the bottom of the shelf it makes getting the hanger on a little tough (IMOP) Hold up a coat on a hanger and measure from the hanger to the bottom for a distance to the shelf. I like about 990mm. Every closet is different, the trick is to standardize as much as possible.
    Lamello
