Dado's before paint/clearcoat
11/29/17
Paul Member
Hey fellas,
I've been developing my own way of doing things (really, like that's uncommon for people like ourselves). I've started to do all my finish work before assembly and ran into a bit of a problem.
I dado all my fixed shelving and use a 23/32 router bit for my dado's. With a few mils of paint, my dado's won't fit very well anymore. I've learned to taped the ends but if the tape isn't perfect, neither is my joint appearance. Is there a sure fire method to taping my ends that will give me good appearance results? tape size? sometime else I can do instead?
Ive thought of bumping up my router bit size but what would be the next size up without too much slop?
Thanks in advance
11/29/17       #2: Dado's before paint/clearcoat ...
Josh Koschak Member
I use strips of plywood I press in to my dados prior to finishing. On the ends of the fixed shelving you could press on a dadoed scrap to prevent film build up and preserving the bare wood for the glue up.
11/29/17       #3: Dado's before paint/clearcoat ...
Bruce H
Eliminate the dado. Use adjustable shelving or screw from the outside.
11/29/17       #4: Dado's before paint/clearcoat ...
Hen Bob Member
We always prefinish the sides before assembly, tape the dado off with painters tape. The dado is usually .03 bigger to allow for paint, CNC helps..
12/14/17       #5: Dado's before paint/clearcoat ...
Jonathan Mahnken
Try finding or having a new router bit made. I use stacked dado blades, so i can adjust for this with shims. I use cheap 3/4 masking tape inside the dado and on the end of the shelf in the instance that they need to be glued together
    Lamello
