bander issues
3/7/18
don fuller
Website: http://wright-ryan.com
we have an older holzher genesis 1435 se.
Every once in a while it wrinkles a piece of banding in the middle of the piece. it doesn't appear to be doing anything differently, any solutions ?
It also drags on the front end trimmer enough to chip the material on the bottom side. again it doesn't always happen. Any ideas on a fix for this one?
3/7/18       #2: bander issues ...
Stuart Douglas
Wrinkle in the middle- usually pressure roller is set too high; it smears the tape as it it stuck at the start of the piece, turn the pressure down on the application roller.
Front end trimmer- check for workpiece edge squareness, check station squareness, clean tracing arm. adjust station pressure. Otherwise, you could try to call stiles tech service and talk with one of the techs, they will almost always get to the bottom of it with you. :)
3/8/18       #3: bander issues ...
bander tech
Are you keeping your incense station filled?
3/12/18       #4: bander issues ...
Pdub Member
You need a new set of chicken bones
