Martin slider
5/12/18
Blade won’t return all the way to 90deg
5/12/18       #2: Martin slider ...
Keith Newton
Ive never used a Martin brand, but on others, sawdust can get packed between the elevation hand wheel shaft and the cabinet opening preventing it from returning all the way back up to 90º.
Otherwise, I'm sure there is a bolt somewhere usually at the back of the trunion that should stop it at 90. If the locking nut was loose, maybe vibration allowed it to turn out some.
5/13/18       #3: Martin slider ...
I did have an old Martin, when that happened it was saw dust as Keith indicates.
5/13/18       #4: Martin slider ...
I assumed that it was sawdust but can’t even see the trunnion or any working parts
It is a t71 slider
5/19/18       #5: Martin slider ...
Joe Calhoon
I believe the T71 has the hydro tilt and blade lift?
Probably similar to my T72. Mine has a adjustable stop for 90 on the end of the hydraulic cylinder. It’s the black bolt under the silver rod in the photo. You have to open the rear access door and tilt the saw to see this. At least on the T72.
View higher quality, full size image (2803 X 3737)
    Lamello
