Panel Genie
looking for stainless inset hinge solution for outdoor kitchen
5/14/18
Peter Matos Member
Hello,
We are a custom cabinet shop in south Florida and have been making a lot of outdoor kitchen cabinetry for clients on the ocean. Even stainless hardware has suffered corrosion issues in this climate/weather. Most of the installations are overlay doors but we have had requests for inset hinge applications. Wondering if anyone has any good recommendations for an inset full stainless hinge that will weather the storm. We have been using the sugatsune slides and hinges but they do not offer an inset model apparenlty? Any suggestions would be greatly appreciated. Thanks in advane...
5/14/18       #3: looking for stainless inset hinge s ...
Pete D
You need to look for 316 Stainless which is the marine grade alloy. 304 is the most common alloy, but doesn't contain molybdenum which makes 316 more resistant to pitting and corrosion in harsh marine/coastal environments.
I believe sugatsune makes them. Any marine supplier should carry them.
5/14/18       #4: looking for stainless inset hinge s ...
Peter Matos Member
Thanks for that recommendation. I understand the differences between the two materials but was unaware that stipulating one or the other was even in the realm of possibility from the various manufacturers. Are there any good marine based manufacturers that you would recommend? Thank you..
Pete
5/14/18       #5: looking for stainless inset hinge s ...
Pete D
There's lots of companies, including sugatsune, that make 316 butt/surface mounted hinges. I'm assuming you're looking for a concealed or euro style inset hinge which unfortunately I've never encountered. I would reach out to some people in the yacht industry, from brokers to suppliers and see if they can't give you a lead. If that's a dead end I would simply offer those cabinets using one of the 316 hinges that are readily available whether it was a mortised butt hinge or surface mounted. Regardless, the alloy used should be readily available from the manufacturer if not clearly advertised.
5/14/18       #6: looking for stainless inset hinge s ...
Pete D
Out of curiosity I did a few searches and found what's listed as a concealed 316 Stainless overlay on alibaba but you have to order 2,000 and I didn't see an inset version.
There's a couple frameless inset versions on amazon from Uxcell and FYRONDY but they're only available in 304.
Can't speak to the quality of any of these but it seems like there may be a 316 concealed inset out there...good luck.
Alibaba link
5/14/18       #7: looking for stainless inset hinge s ...
Pete D
First link is the 316 overlay, this one is the 304 frameless inset.
304 Frameless Inset
5/14/18       #8: looking for stainless inset hinge s ...
Jake Member
I just encountered this same situation... we ended up using the Sugatsune hinges. I downloaded the dxf of the hinge plate and offset the shape by a 1/16” cut out of 3/4” teak on the cnc. Worked well
5/15/18       #9: looking for stainless inset hinge s ...
Peter Matos Member
hehe I found the exact same ones and we ordered a few to inspect them to see how they look. I also considered using the sugatsune models and blocking out the face of the inside of the cabinet as the last poster suggested. Kinda curious that they do not seem to offer this hinge anywhere that I could find. Thanks for all the suggestions guys. Still investigating the marine supplier side of things.
Pete
    Lamello
