Edgebanders Sprayers before buffers?
6/25/18
Bob Stern
Hi All,
Looking to upgrade our bander.
I have been getting conflicting info from 2 major vendors.
We only do 2mm pvc.
One says sprayers just before the buffers helps restore shine to scraped pvc without having to push the buffers so hard.
The other says the only reason for them is for running PUR glue. That it does not help put a shine back on the PVC.
Anyone have any experience using a spraying agent to help the bufferers bring back a shine?
6/25/18       #2: Edgebanders Sprayers before buffers ...
Have never used them. I thought they were supposed to help remove glue residue. Used in combination with a resist put on at the very beginning of the machine.
6/25/18       #3: Edgebanders Sprayers before buffers ...
Rich  Member
We use the release agent at front of machine before the pre-mill and then the cleaning agent before the buffers. We use .018 tape and 3mm.
We get very little discoloration on 3mm after scraping as long as the cutters are set correctly and the scrappers are sharp. The release and cleaning agents do make a significant difference in getting a very clean panel from bander.
Once again if the cutters and scrapper are set correctly there is very little discoloration of edging, we also have a heating station on our bander that we never turn on as it does not make that much of a difference in quality of edge.
6/29/18       #4: Edgebanders Sprayers before buffers ...
Chris Boyer Member
Website: http://coffeymachinery.com
Reipe is the brand of spray system most often used. Each bander vendor uses some version of what they have. Reipe is supplied in the USA by Adwood Tapes and Tools out of NC. They have a breakdown of functions and purpose of products on their site.
Reipe in USA
6/29/18       #5: Edgebanders Sprayers before buffers ...
Bob Stern Member
Spray onto the upper and lower edge area of the workpiece. Removal of release agent and loose glue residue. Cooling of the edgeband and glue joint. *** Matt radius of the machined edgeband re-matches the surface finish. ***
Looks like it might be worth a try.
6/29/18       #6: Edgebanders Sprayers before buffers ...
Bob Stern Member
From Reipe site:
Stiles has it at $350 for 30 liters.
Looks like 1 liter does 2500 meters
so about $0.005/M. Plus cost of adding sprayers.
Seems reasonable.
7/3/18       #7: Edgebanders Sprayers before buffers ...
Chris h
Sounds to me the salesman needs some training on the purpose of buffing. The purpose of the buffing is to make the edge softer and take the square edge off it and to help to take small amounts of excess glue off. To restore the shine and color of the 2-3 mm, you need a reheat section. When you scrape think pvc they turn white ish and heating them up brings the color back out.
