Scoring Blades
12/2/18
Jeff
I have a couple questions about scoring blades, the first one is what is the depth that a scoring blade should be cutting at to get the ultimate performance.
The next question is what are the Dimar adjustable scoring blades like? They look like a good idea, but I was wondering if they move at all when you start cutting?
12/2/18       #2: Scoring Blades ...
Just enough to break through the surface of the veneer usually. If the panels lift off the surface you may have to push it up higher.
I'd say a 1/16" should fare well. If you could keep the panel flat to the table then a 64th would probably do with todays veneered sheet goods.
12/3/18       #3: Scoring Blades ...
Harold morantz
Website: http://morantz Cabinets.com
We have two 10’ sliders and use the two piece scoring blades with metal shins that come with them. This gives us the most flexible form of adjustment.
