Commercial laminate doors
12/17/18
Al
I have a project that architect is calling for laminate on moisture resistant plywood for doors. I never make doors out of plywood only mdf or pb core. My supplier has moisture resistant mdf. Assuming I get approval for this mdf does this stuff work like regular mdf ? Does it lay flat? Any problems with glue adhering to it? We usually use pva glues for laminate to core lay ups. Specifically Wilson art 3000 glue.
Thank you for any info
12/18/18       #2: Commercial laminate doors ...
KM
We've used moisture resistant cores with both MDF and PB and have never had any issues. We just treat it like any other sheet of MDF.
12/18/18       #3: Commercial laminate doors ...
Bruce H
I did a coffee shop using Wilsonart on two sides of mahogany marine plywood. My normal board supplier laid it up the same as if it were PB core. It just cost more. What a dream to work with.
12/19/18       #4: Commercial laminate doors ...
al
Good info, thanks
