Suggestions on handling euro sized sheets
3/13/19
Carmine Member
Many of these new textured melamine products on the market today measure 7'x9'. We are a 6000sf shop with no forklift or room to store one.
Anyone know why they are manufactured this size?
Suggestions on carts or other means to safely maneuver and load onto machinery would be appreciated. I know from reading other posts Hafele makes a tilting cart but haven't been able to locate on their site and if I could would it be able to handle sheets this big.
3/13/19       #2: Suggestions on handling euro sized ...
Ryan
We have had one of these for a long time over 10 years. It works wonderful. It will flip flat and raise to about 36". It will hold 10 sheets of 3/4" standing up. I don't see a reason to buy anything bigger than the 4' or maybe the 5'. It won't hurt for the panel to hang off some.
https://www.shopcartsusa.com/Product-PanelHandler.html
3/14/19       #3: Suggestions on handling euro sized ...
Chris
Used to work in Germany years ago. Its very common to see:
4x8
6'9"x9'2"
6x10
8'6"x 3'3"
Im sure it has to do with making the most of a board for your project since dump fees are SKY HIGH
3/14/19       #4: Suggestions on handling euro sized ...
Bruce H
If you have a 6000SF shop and the machinery to cut panels you can't afford not to have a fork lift. Put you sheets on a scissors lift. I have one with wheels and a handle, the others we move with a pallet jack.
3/15/19       #5: Suggestions on handling euro sized ...
David Rakauskas
Website: http://csaw.com/striebig
Carmine,
The textured melamine's are made that size because that's the European Standard. We recently installed several Striebig vertical panel saws to cut these as they've become very popular the last few years. Most people don't have a router that can handle this size and they're a bear on a slider so a Vertical works fantastic for them.
Larger standard panels is also the reason you will see 3 times as many vertical saws at the LIGNA show in Germany than say Atlanta here.
When you talk large panels and have a space issue, a Vertical Saw with vertical panel material handling like the shopcart is definitely the way to go.
Dave
3/16/19       #6: Suggestions on handling euro sized ...
Harold morantz
Website: http://morantz Cabinets.com
Our shop is 3600 sqft and couldn’t live without the forklift, we bought a 6’ extension for these panels although I try to stay away from them, I bought my forklift used 14 years ago fir 1800.00 and have not put more than 500.00 pieces not it for standard maintenance since then. We unload shipments in minutes and use it to stack our panels in racking to save space,
Also as a lift when we are cutting up a bundle of sheet goods. Safer for my guys and it doesn’t travel more than 30ft in a week except to unload from supplier.
6/23/19       #7: Suggestions on handling euro sized ...
Tom
This is the size of a sea can for maximum shipping
