Cabinet hardware application help
3/13/19
Kevin Member
I have a cabinet design idea, however I am having trouble figuring out what hardware can be used to perform the needed function. he cabinet will have 2 banks of drawers. I would like each set to be able to be pulled all the way forward, separately , then swung open like a door to expose another storage area behind. Any assistance would be helpful.
View higher quality, full size image (1198 X 958)
3/15/19       #2: Cabinet hardware application help ...
Steven
It might be possible you could make something like that work with pocket door hardware if the drawer box weren't to heavy to be supported by a couple hinges on one side. Hinge the box at the back like you would a door and use pocket door slides twice as long as the drawer box length. Of course your cabinet box would need to be deep enough to accommodate the pocket door slide.
3/15/19       #3: Cabinet hardware application help ...
Kevin Member
I had thought of that. Based on the hardware I looked at, if you try to operate the the glide, basically, with the door closed. The hinge hit the slide mechanism. Under normal conditions, the hinge rotates out of the way when the doors are opened before going back.
3/15/19       #4: Cabinet hardware application help ...
Steven
Just brainstorming here, but maybe there is a way to fasten a piano hinge to the pocket door glide in place of the euro hinges in a way that it wouldn't interfere with the operation of the glide when the drawer box is in the closed position?
It's been a while, but I remember having to cut a piece of wood to span the two pocket door glides when using them and maybe a piano hinge could be fastened to that and the box.
3/15/19       #5: Cabinet hardware application help ...
Steven
You could also just fasten a panel to a couple basic full extension side mount drawer slides and then hinge the drawer box to that panel with a piano hinge so that when the panel/box assembly was fully extended out of the cabinet the box could be rotated out of the way.
3/15/19       #6: Cabinet hardware application help ...
Steven
Pic
View higher quality, full size image (1828 X 898)
3/15/19       #7: Cabinet hardware application help ...
Steven
One last thing. You could make that work the way you had it drawn by using a glide half the size of the case, installing it at the very back and then hinging the back of your drawer box to the front of the panel. Also on the left side of the box put a rail that guides it along a grooved guide mounted on the left side of the cabinet to keep the drawer stable while moving in and out.
4/17/19       #8: Cabinet hardware application help ...
xedos
What are you trying to accomplish with this design ? I think it’s suspect from the start.
The amount of load on the runners (and hinge ) is going to be immense when the assembly is open. A full length piano hinge would probably carry the load, but you’re going to need VERY stout runners.
The drawers, their runners, and the carrying frame are going to weigh a couple of hundred pounds by themselves. That could double depending on what’s stored in them. Accuride’s vehicle division has super heavy duty slides that will easily carry the weight But they’re very thick and cost several hundred$ a piece. That is going to make concealing them problematic.
More context might help.
