Re facing with WOW
4/1/19
Jeff Christenson Member
Website: http://www.jeffscabinets.com
I read a great thread here about re facing cabinets using WOW (wood over wood). I have never done a re face job but work is slow and I have a chance to bid a re face job. The cabinets are Omega, they are only three years old and are painted white. Customer wants to change the color and add a few doors to some open areas. I pretty much get the idea but have a few questions. Mainly, the WOW is pretty thin ( .035") close to 1/32". It comes rolled up in a 48" box. Can the WOW be finished with a pigmented lacquer ( I use ML Campbell Magnamax) in large sheets then ripped to size? Will the finish be OK on a flexible surface like that? And, once you trim with a laminate trimmer will that 1/32" edge show a dark line? Also, what product is recommended for the sides of the cabinets, some of the wall cabinets are 54" tall ! Thank you for your time!
4/1/19       #2: Re facing with WOW ...
Pat
I've done exactly one refacing job and it was wood - Walnut veneer with peel and stick backer. I prefinished the sheets using waterbased stain and clearcoat and there was some rippling of the veneer after the finish dried, but it flattened out fine during application.
The most painstaking part is doing the face frames. There's a lot of cutting and trimming to do, especially if you need to do the inside edges of the frames. I used a Virutex laminate slitter and a guillotine style paper cutter to cut the strips and that helped a lot. I'd imagine that the edges will be noticeable on a white painted job, as will your rail and stile joints.
I'd order some sample material and try everything first. Oakwood veneer sells a phenolic faced "veneer" designed specifically for paint grade jobs. I haven't tried it myself. You're right to worry about the larger end panels. The peel and stick adhesive is not forgiving. Once it sticks, it's stuck!
I spent a full week in the client's house doing a small kitchen, but I also replaced all of the doors and drawer fronts and added/modified a few cabinets. I charged almost $10k for all of the work and it wasn't enough.
Good luck!
Paint grade veneer
4/1/19       #3: Re facing with WOW ...
Thanks Pat! The more I think about how particular this lady came off and the way this kitchen is laid out I think the best thing to do would to be honest with her and tell her she wont be happy with a re-face job. The cabinets are really nice, just the wrong color. I think I will suggest replacing them with new ones. I cant see a re-face job looking better than whats there now.
4/1/19       #4: Re facing with WOW ...
Kind of a basic question, but why resurface when all you are going to do is repaint it? Clean and scuff the existing paint and then shoot a new color.
4/2/19       #5: Re facing with WOW ...
The first thing the lady said to me was "I dont want to paint" which made no sense to me. Im not interested in painting cabinets on the job site so I did not go down that road. I was just hopeful for some work but after thinking about this I decided to call her and tell her that refacing would not look as good as the existing cabinets. I told her the correct way to do this is to buy new cabinets. I offered to give her a quote and she is thinking about it. There is no doubt in my mind that if I was to reface this kitchen she would be unhappy and I would never get her off my back.
4/2/19       #6: Re facing with WOW ...
Matt
I think you made the right call here Jeff.
I cannot imagine, however, why she'd want to "change colors" but not repaint. It's not like you're merlin the magician or something.
A brush, with the proper paint, in the hands of a reasonably skilled painter can look quite good. I've brushed several kitchens myself that turned out just fine (albeit, in lower sheens, which is how it turned out fine with a dunce like myself brushing it).
4/2/19       #7: Re facing with WOW ...
Pat
Another option would be to remove the cabinets and spray them in the shop. Not easy with appliances and countertops, etc., but probably cheaper than new cabinets.
4/2/19       #8: Re facing with WOW ...
Yes, I did consider suggesting to her taking the cabs to the shop to spray them. When I do my finishing I spray all my parts first then assemble them, that way most of the spraying is done flat. Im not confident enough to spray assembled cabinets. Besides the interiors of these cabinets are white as well and if she wanted the inside painted then forget it for sure.
