edge sanding large quantities of thin ply
4/8/19
bill
Looking for a solution to edgesand 1/4" x 96" appleply. 200 lineal plus per month.
Needs to maintain square edge and overall width dimension. Now we are using a sanding disc on a dedicated table saw. Not able to use a feeder with this set up.
Any ideas?
4/8/19       #2: edge sanding large quantities of th ...
200' per month is only 10' per day. Just about any method should not be an issue. I'm confused with your two dimension given. Is there a strip width, or is it 1/4" square by 96"?
4/9/19       #3: edge sanding large quantities of th ...
bill
Various widths from 1" to 4".
200 lineal per run. +-
once or twice a month now. Could be much more.
Takes less than an hour now. But the quality is not what we would like it to be.
4/9/19       #4: edge sanding large quantities of th ...
Pete
Assuming you have a shaper... I would first try a sanding head as a low cost remedy to take advantage of the split fences and feeder. Abrasive life would not be good, but adjusting the spindle height in 1/4" increments takes seconds to utilize the full height of the sanding head.
For a more effective dedicated solution I would look for an oscillating split fence edge sander. Kundig and older Unilev models occasionally come up for sale in the US, many more available in Europe. Baileigh also has an import knock-off, although I don't know if you can mount a feeder on it.
4/9/19       #5: edge sanding large quantities of th ...
Matt
I cannot improve upon the sanding suggestions made above.
I'd spend some time trying to find the cleanest possible way to cut this. Are you cutting this with a CNC, straightline rip, or tablesaw?
In my shop, we'd only be hand-ripping this on a tablesaw. I'd be using the best 80-tooth 10" blade I could find and making sure the operator knew to make the cuts with less aggressive feed speeds.
A zero-clearance throat also, if the underside must also be splinter-free.
4/9/19       #6: edge sanding large quantities of th ...
Okay, that's better information. I'd build a couple sleds to sandwich all the common width parts vertically and run it through a wide belt. Think of something like a printing press board with a rim around the outside and wedges to squeeze all the parts together.
