Heavy appliance lift
6/2/19
Chris Member
I am being asked if we can add an appliance lift for a 12 quart Hobart stand mixer to a kitchen we are working on. The problem is the damn thing weighs 190# and all of the lifts I see only support things in the 30-60# range. Have you guys seen anything that can support an appliance that heavy? Thanks.
Hobart specs
6/3/19       #2: Heavy appliance lift ...
MarkB Member
I cant imagine any commercially available lift that is practical would ever handle the weight and the use. We have had issues with mixer lifts when people use the largest kitchenaid mixers or other HD euro style mixers and they run a double or triple batch of bread dough. When those mixers are run on the counter they jump and shake around and its worse when its on the lift.
6/3/19       #3: Heavy appliance lift ...
Paul Miller
In addition to owning a cabinets shop, I also own a bakery. We have two Hobart mixers. The small one is 20 Qt mixer. This is the next size up from the 12 Qt you have. I agree with MarkB. I wouldn't even mount one of these on a counter. Our 20 Qt is mounted onto a stainless steel cart with casters. It is bolted to that cart and if it is mixing a large batch, the stand will be rocking and moving a little. We have locking casters. Who ever designed that layout probably does not have experience in a bakery or commercial kitchen. Be gentle and explain it to them.
Smart post. Good question.
6/4/19       #4: Heavy appliance lift ...
Adam B Member
Another thing to consider is the overall size of this thing. Most of the kitchen aid mixers (which these were designed for) stand about 14" tall and require a 23" tall opening minimum to allow enough swing for the lift & mixer to clear. I see on your unit, the appliance height is 29" tall. you would need a very tall opening for this thing to swing open. This unit just isn't designed to be built into a cabinet on a lift system. Like mentioned above, be polite,but educate your client and look for a better solution.
6/8/19       #5: Heavy appliance lift ...
Chris Member
Thanks guys for the feedback. They now want an appliance cart that fits into the pantry to hold it. Oh joy.
