spline cutting router bit
6/13/19
Joe Member
looking for a 1/8" spline cutting router bit with a 3/8 shank. The cutter has to be integral with the shank. In other words no nut fastening the cutter to the shank, flat on the bottom.
Any info appreciated, thanks
6/13/19       #2: spline cutting router bit ...
You may look at something like the Amana 45672 or CMT makes a similar option that we have but it's a 1/2 inch shank. I don't know if it's available in 1/4 inch shank. You can remove the bearing if you don't need it. If you go with a 1/4 shank you could run an rb108 bushing to get you to 3/8
