Kreg Faceframe Table Setup/Suggestions
6/17/19
Josh Koschak Member
I am about to receive my first faceframe table. I was able to find a lightly used on on the exchange here.
What tips, tricks, and jigs do you have to offer for a faceframe assembly area? I currently build mine on a flat table which is uncomfortable ergonomically and inefficient.
If you have any great ideas or photos, I would love to see other setups.
Thank you,
Josh
6/18/19       #2: Kreg Faceframe Table Setup/Suggesti ...
SteveL Member
Your going to love it, so much easier than building flat. I have a couple of suggestions. Place the table right in front of the saw and pocket hole machine, you can cut the parts as you need them and do it with just a few steps in any direction. I put mine on casters so I can move it out of the way when I'm done with FFrames.
I don't know about the kreg table but its common to see guys build a holder for screws, glue and the drill, give them a home and you wont have to look around for them.
Cut spacer blocks for your most common drawer openings and build the frames upside down. I stick mine to the framing of the table with magnets so they stay with in reach.
Last I would get some glue release to treat the table and clamps. I use the stuff from UC coatings, amazing stuff, brush a little on every few jobs and the glue never builds up. You'll be glad you did. Good luck.
