Edgebander Coil Feed
8/29/19
MarkB Member
I cant remember if it was in a trade magazine or a video I had recently seen with a new bander holding the coil vertically below or possibly at some sort of an angle below the infeed conveyor and the banding was routing up and into the bander with a bit of a twist in the banding. Wondering if anyone has every played with relocating their coil support table or angling it slightly to allow it to tuck under the infeed end of the machine or perhaps angling the support table upwards rather than projecting straight out the back?
We are doing a bit of rearranging in the shop and the layout we are hoping for would make it nice to be able to recapture some of that space. Not putting any influence on the banding as its coming into the machine would be critical and wouldnt seem much of an issue with thin banding but looking at it initially we even figured it wouldnt be too bad a mod with 3mm.
Thought I'd toss it out there as Im sure theres something Im not considering.
8/31/19       #2: Edgebander Coil Feed ...
Larry Schweitzer Member
The banders that have multi roll feed magazines don't seem to have any problem with a 90 degree twist. They are common on the bigger machines. Look at Homag, Stefani, etc. banders.
9/2/19       #3: Edgebander Coil Feed ...
MarkB Member
Thanks Larry,
We opted to give a try to an adjustable mod. Our coil table sits on a square tube arm. We cut the vertical and horizontal arms and welded round bar into one end of each sleeved into the other end an welded a nut with a lock screw into each so now the coil table can be swiveled horizontally as well as rotate tipping the table to any angle vertically. We keep the bander on casters but this means we could literally push the bander right up against a wall and still run it (It would have to be rolled out for access to the rear).
Makes a huge difference in a tight layout to be able to regain 2' or so along the entire back of the bander. Havent run any 3mm yet but it doesnt look like it will be an issue. We added a small guide roller on the coil in-feed plate so the banding comes in exactly as it did before.
At least if we come across some unforeseen problem we can just rotate it back.
Thanks again.
9/2/19       #4: Edgebander Coil Feed ...
We need to do some modifications to our layout to gain a little efficiency. Built new offices, now need to tear out the old and move the contour bander & trimmer so they can be served by the transfer car on the conveyors. Will also be moving the edge sander and arched molding machine to closer to their optimal locations. Will need to have some electrical & ducts run. It will save some steps. Will also gain me some space in my metal working area.
