Blue wax filler ?
2/6/20
Tom Gafgen
I need to fill some nail holes in some pre finished medium blue Crown molding would prefer to use soft wax but don't know how to make the blue any ideas on what I could use The finish is conversion varnish so I would prefer not to have to do any painting in the field
2/6/20       #2: Blue wax filler ? ...
MarkB Member
Color glazing compound with artist colors? Thatd be my choice other than something like seamfil
2/6/20       #3: Blue wax filler ? ...
Tom Gafgen
Thanks Mark I wonder if mixing some of the CVwith glazing compound will work?
2/6/20       #4: Blue wax filler ? ...
Josh Koschak
Could you use a crayon? Seems too simple to work.
2/6/20       #5: Blue wax filler ? ...
Tom Gafgen
That sounds like a great idea Josh I'll have to go get some and give it a try
2/6/20       #6: Blue wax filler ? ...
Mohawk (Fil-Stik) probably has the blue you are looking for.
I know you can get some of the colors from Amazon so if you have prime you might be able to get them quickly.
I saw at least 6 blues in the list.
I know I have at least one or two blues in my collection. Hope I never have to use them LOL
Mohawk Fil-Stik
2/6/20       #7: Blue wax filler ? ...
I have just filled this with whatever and touch it up with paint matched by the paint store and an artist brush.
Our standard specifications, hammer and file to fit and putty and paint to match.
2/6/20       #8: Blue wax filler ? ...
Tom Gafgen
Thanks Leo I'll order a couple those blues and even some grays from that Mohawk list and I should be able to cook up an exact match , thanks everyone for the help
2/6/20       #9: Blue wax filler ? ...
I spent $400 with them a while back and got a lot of crayons, rattle can lacquer and some other things. I've upgraded over the years and I now have over 180 of their Fil-Stik crayons colors along with the Blendall sticks and some markers.
The nicest thing about them is they aren't just wax, they have aluminum in them and you can apply finishes over them. I've applied pre-cats, CV and 2K poly over them with great results. Works nice when you are filling pin holes in primer in the booth. No dry time.
2/6/20       #10: Blue wax filler ? ...
Patrick Gilbert
Leo
Are you talking about the sticks that are hard or softer blend sticks?
2/6/20       #11: Blue wax filler ? ...
I talked about both. But the Fil-Stik is what you use to fill holes in trim and during the finish process. It is finish-able because of the aluminum.
The Blendal sticks are too soft to fill holes and they are used for covering mistakes like burning through the stain on a corner. Apply the Blendal stick and wipe with your finger to blend it into the mistake and then finish over it. Used for stains.
2/6/20       #12: Blue wax filler ? ...
It seems to me that the fill sticks are hard (not soft) and not that easy to use on a painted surface.
2/6/20       #13: Blue wax filler ? ...
They are not putty soft. They are crayola crayon soft as opposed to hard wax which is usually melted into the hole or damaged area.
With the crayon you rub over the hole until it fills and then take a cloth and rub the excess away. When I'm filling while finishing if it's a flat surface I scrap the excess off with a plastic card or razor blade.
But on moldings I just wipe it with a paper towel.
2/7/20       #14: Blue wax filler ? ...
Picture framers use colored waxes to fill nail holes from joining pre-finished moldings.
This link has some colors, but there is another manufacturer of waxes with more colors. Easy to use.
https://framingsupplies-shop.com/nail-hole-and-corner-filler
2/10/20       #15: Blue wax filler ? ...
KCR
I keep a hot air gun with my color sticks along with a large stainless measuring spoon. I cut off how much fill stick I think I need, melt it in the spoon and blend different colors together to get a match if the sticks aren't quite right. I use a small pallet knife to apply the hot fill stick color right onto the nail or pin hole. I fill everything that is needed then come back over the excess filler with the hot air gun just to soften the wax and rub with a clean white rag. This eliminates the excess rubbing to remove the wax. I also used the blue stick from Mohawk about a year ago, mixed with a little white and got a perfect match.
2/10/20       #16: Blue wax filler ? ...
Thanks, I learned something
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
