Modified overlay question
4/19/20
Perry Vavra Member
Have a request for some modified overlay cabinets Dallas, Ft. Worth area. Not familiar with this style. Wonder if someome has some pics or drawings they'd be willing to share along with some face frame stile and rail dimensions and reveals between doors an drawer fronts. Thanks
4/19/20       #2: Modified overlay question ...
No idea what a modified overlay cabinet means. Must be a Dallas-Ft Worth thing.
4/19/20       #3: Modified overlay question ...
Probably 3/8" overlay with a 3/8" rabbet around the door.
4/19/20       #4: Modified overlay question ...
I always called those 3/8 inset.
4/19/20       #5: Modified overlay question ...
We do something we call modified full overlay. Kind of a mix of inset and full overlay. Basically the stiles and the top rail are exposed.
View higher quality, full size image (900 X 603)
4/20/20       #6: Modified overlay question ...
Found this glossary
http://cabinets-q-and-a.com/kitchen-cabinet-design-overlays.html
4/20/20       #7: Modified overlay question ...
Kevin
I was seeing red reading the articles on custom vs factory , not true baking a finish on solid wood does not end well.
The big difference is cabinets made in a factory are cheap period .No need to debate period.
http://cabinets-q-and-a.com/factory-custom-cabinets.html
4/20/20       #8: Modified overlay question ...
D Brown
Perry, I use 5/8" overlay with 1 1/2" stiles and rails, this gives you a 1/4" reveal between door and drawer fronts and is a pretty tight look and easy to do and comes out perfect. Good luck.
4/25/20       #9: Modified overlay question ...
keith farr
D Brown We do a 11/16" overlay with a 1 1/2" frame giving us a 1/8" gap I use a Blum cliptop 110 hinge with 0 MM plate What hinges and plates are you using for the 5/8" overlay? The 1/8" looks good and match pair door gaps but is not very forgiving Have thought about 1/4" gaps , just haven't tried yet.
