Base/Upper Cabinet Alignment
6/10/20
Steven
At the end of a run of cabinets I have always vertically aligned the base and upper cabinet. I've noticed that some tilers bring their tile backsplash all the way out to the end of the countertop which already overhangs the base so that the tile also overhangs the upper cabinet which looks bad to me.
Measuring for a 60s built kitchen remodel I noticed the end base cabinet was offset from the upper the amount of the countertop overhang so that the full height laminate backsplashes came to the end of the counter top and aligned with the uppers.
I'd be interested to hear if any of you other cabinetmakers on here offset your end base cabinets from the upper and/or think it looks odd when the cabinets are aligned vertically but the backsplash is brought all the way to the edge of the countertop, overhanging the upper above?
6/10/20       #2: Base/Upper Cabinet Alignment ...
Mark
I agree with your assessment of the tile going to the end of the counter and not aligned with the upper- looks wrong. If the base and upper are aligned, tile should stop at the cab box line, counter goes past the amount of overhang- just like a window stool.
Having the upper align with the end of the counter is an acceptable work around I guess, as you know the tile people are going to the end of the counter, no matter what you say or the elevation might show
6/10/20       #3: Base/Upper Cabinet Alignment ...
CGiles
Did the tile guys do this when the uppers were in place? If so, they are morons and need to make the correction so the tiles stop at the edge of the uppers. If the uppers weren't installed when the tile went in, it is a bit murkier situation.
6/10/20       #4: Base/Upper Cabinet Alignment ...
Steven
Yes, every time I have seen tile guys do this in recent years the upper cabinets were already installed, and I couldn't imagine why they thought it looked good to let the tile hang out past the upper.
6/10/20       #5: Base/Upper Cabinet Alignment ...
I think cabinet ends on the same plane is correct, and tile should stop at the edge of the cabinet.
It'd look stupid, (I think), if close to the edge of a wall and there's different reveals to the edge of the box work.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
