Stroke sander
6/20/20
Jeff
I am curious as to how many people still use a stroke sander, are they a thing of the past?
I had an old one and I couldn’t give it away, I haven’t seen many for sale anywhere.
What has replaced them if they are a thing of the past.
20 year ago they were excellent for the final sanding pass when sanding 6 mm solid edging for birch plywood, that was the school boards go to cabinet, everything was birch plywood.
Maybe now with the new edgebanders, all the pvc edging things have changed.?
Maybe I will make a bandsaw mill out of it? Hhmmm!
6/20/20       #2: Stroke sander ...
CGiles
I use mine every day. I wouldn't be without it. I just came up from flush sanding a batch of soft maple doors for the next kitchen.
6/20/20       #3: Stroke sander ...
I want to modify one just for sanding the outside sides of assembled dovetail drawers.
We pitch everything else through a widebelt.
6/20/20       #4: Stroke sander ...
Warren E Member
every old european I knew had one.
I built my first one then had a progress and no love for it. Then got one from one of the old guys i knew. Itailan, power table up and down, open end right hand side so unlimited. Zero chance id be in this trade without one.
Karl there are no mods, you just screw two pieces of wood into the wood table and set your drawer on top hanging down. Ive done whole solid wood cabinets that way. Excellent for that no wide belt can touch that.
When you have the feel there is lots they can do. Sanded lots of rails and styles on assembled doors doors but it takes care. They range at auctions from around 700.00 to 2,200 on the high side plus buyers premium.
7/25/20       #5: Stroke sander ...
Kevin
Widebelt sanders took over, and changes in materials and methods of work! I have a stroke sander that is very unique. the entire machine is suspended from over head and literally can allow the user to sand an unlimited sized work piece. I had the opportunity to use it in a shop where I rented space and a couple years later when the owner put the machine up for sale I jumped on it. I love stroke sanders for situations where a widebelt just can't do the job. I am selling it because I was forced to close my doors for health reasons.
