Need cab hinge that will auto-close
8/9/20
Walter Member
Client has an upper cabinet door near the sink that she accidentally leaves open. She then bangs her head on the open cabinet door. Because she's in her 90s that's a health concern! She wants a door that will not stay open but will slowly and gently return to closed if she forgets to close it. I haven't been able to find such a hinge. Any ideas?
8/9/20       #2: Need cab hinge that will auto-close ...
Never seen one that will close from wide open. But you might check the RV hardware market. Lots of cabinet door control needed there.
8/10/20       #3: Need cab hinge that will auto-close ...
Jared E
One idea: convert the cabinet to a Blum Aventos lift-up of any kind, add a servo drive module and the remote control. When it opens up it may be out of her reach but she can close it with the remote button. I've used them and they perform as advertised.
8/10/20       #4: Need cab hinge that will auto-close ...
Hang a weight in a piece of pvc in the back corner? Notch the shelves around it?
Just an idea, likely not a great one.
8/11/20       #5: Need cab hinge that will auto-close ...
rescraft
@Karl Brogger---Rube Goldberg would approve!
8/21/20       #6: Need cab hinge that will auto-close ...
Yana R
Website: http://sugatsune.ca
There is an option of a spring butt hinge, that will allow to keep the door shut, these are often used in RV and Industrial applications:
https://www.sugatsune.com/product/butt-hinge-w-spring-3/
9/18/20       #7: Need cab hinge that will auto-close ...
Peter Matos
I would think that a small and short self closing spring closer could be adapted rather easily into the top of the cabinet to pull the door closed slowly. It would of course add a bit of resistance to the opening of the door but if you played with the placement and leverage the location a bit I would think it would be possible to get something that would be reasonably light yet still close slowly and surely. I also found this item on amazon that appears to do something similar with an internal spring(See link below). Final question is what is a 90 year old woman doing the dishes for anyway ;)
Pete
Door Closer
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
