Slide out drawer lock
12/17/20
Mike D  Member
I'm looking to lock out the Blum Moventos slide at full extension, to keep stabilized for a cutting board drawer.
Blum has a lockout but it doesn't work with a standard dovetail drawer.
Basically something that attaches to the drawer side and pops out when it passes the front edge of the cabinet.
Then simply press it in to return the drawer to closed position.
Has anyone seen anything on the market for this?
12/17/20       #2: Slide out drawer lock ...
Maybe you could make something from the RV/Boat industry work.
12/17/20       #3: Slide out drawer lock ...
https://www.amazon.com/dp/B00CTIK9AM?tag=picclick0f-20&linkCode=osi&th=1&a
mp;psc=1
12/17/20       #4: Slide out drawer lock ...
Mike D  Member
Very interesting.
Thanks for that different line of thinking. I might look into parts for rv's as well.
12/17/20       #5: Slide out drawer lock ...
Kevin B
I think your taking about the blum pull-out shelf lock...it can work on drawers though not intended for it, you'll need about 10-15mm on the inside for clearnce of the latch, id say buy it first, its a new product so blums docs are not great, also opposing magnets or ball catches can work.
12/18/20       #6: Slide out drawer lock ...
Peter M.
Thank you for asking this question I have an installation that would be perfect for this new Blum pull out shelf lock. Was not even aware that existed. Appreciate the heads up.
Pete
12/18/20       #7: Slide out drawer lock ...
Mike D  Member
Yes, the Blum system is pretty straightforward as long as you make you shelf or box to the required specs.
12/18/20       #8: Slide out drawer lock ...
Peter M.
Oh well I just got off the phone with Blum customer service the shelf lock open system is not yet available apparently. They said it might be ready by the first of the year which is not all that far away but currently not available. Yes we use Blum products all the time we are quite familiar with them altho this was something new to me.
12/18/20       #9: Slide out drawer lock ...
Mike D  Member
Peter are you in the U.S or Canada?
I'm in Canada and have used them already.
12/18/20       #10: Slide out drawer lock ...
Peter M.
We are in USA Florida. Blum Customer service said they are not available. Maybe they meant not available here I dunno. How do you find them? I would like to try them on this build. They apparently work with tandem and movento slides right? Looks like a useful addition to our capabilities.
Pete
12/18/20       #11: Slide out drawer lock ...
Mike D  Member
I'm in Ontario, Canada and purchase most of our Blum from Richelieu.
I know there is a difference between our Countries when it comes to Blum. As most our our products come directly from Europe.
