Modifications to Porter Cable Dovetail Jig for consistent results
12/17/20
Steven Woodward Member
I struggled with the Porter Cable Dovetail Jig model 4212, because it would not give me consistent results in tightness of joint and alignment of pieces. With a few modifications to eliminate variation, I was able to get consistent results. I keep a dedicated router with the bit installed so that I can set up quickly and make a perfect fitting drawer on first try without any adjustments to the jig or router. Saves a lot of time.
Modifications are explained in video
I am interested in any other ideas to improve the Porter Cable Dovetail Jig
YouTube
12/18/20       #2: Modifications to Porter Cable Dovet ...
TonyF
Steven Woodward:
I think once the jig is dialed in, and you have a dedicated router, any variations are usually a function of poorly machined material and sloppy stock preparation.
I kept a piece of the original setup material, and that was the gauge for the thickness of future material, so that at least thickness was not an issue.
If your material is not consistent in thickness and width across the entire piece, if the ends and sides are not straight and square, if your material is not flat, if your parallel pieces are not the same size; this will negate the accuracy of any jig, no matter how precisely set.
FWIW
TonyF
