1/4 inch overlay compact hidden hinge
2/6/21
Butch Member
I'm trying to find some hinges for some pretty close to a 1/4 inch overly, 7/16. How much adjustment do you imagine there is on this type of hinge. These would be screw-in face frame mounted. I'm most familiar with 1/2 inch overlay compact hidden or two-part hinges which have about 1/4 inch of play.
Thanks,
Butch
Hinge
2/6/21       #2: 1/4 inch overlay compact hidden hin ...
Butch Member
The width of the doors is 7/16ths greater than the width of the opening.
2/7/21       #3: 1/4 inch overlay compact hidden hin ...
Thicker plate on a 1/2" overlay hinge? 6mm plate would likely work
2/7/21       #4: 1/4 inch overlay compact hidden hin ...
You're telling us that 7/16" is close to 1/4"? I'd say it's closer to 1/2" on my tape measure.
2/8/21       #5: 1/4 inch overlay compact hidden hin ...
Butch,
The Salice Series S face frame hinge is available with 1/4", 5/16", 3/8" and 7/16" and greater overlays. They adjust 1/16" outward and 1/8" inward.
Also, as Mark mentioned, you can use a two piece hinge an plate combination. In this case you would use a "half" overlay hinge with a 4mm mounting plate.
C2P6G99 Half overlay, self close, screw-on
BAU3R49 4mm face frame mounting plate.
If you are looking for soft close the part numbers would be different but the hinge and plate the same design.
Here is a page from our catalog showing the Series S options. Also, here is a link to our web site for additional details.
Best of Luck
Dennis
Salice America
View higher quality, full size image (1046 X 1358)
Salice Face Frame Hinges
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
