Alternatives to Baltic Birch ply
4/19/21
Brent
My Western Canada supplier's stock on 12mm baltic birch plywood has been exhausted (apparently Russia is choosing to send it to Europe vs. NA). I make all of my drawers out of BB: 12mm sides and 6mm bottoms. I use lock joints for joinery, do not edgeband any joints/edges, and use a clear finish applied in-house. This system has worked well for the past 10 years... I now need to find another material to use besides BB because the supplier's outlook is grim. Any suggestions? Should I transition to a solid wood, if so what species? I have access to a 12mm import plywood but my past experience it turns into a banana fairly readily. I'm sure I'm not the only one facing this supply issue so I'm interested in how other's are addressing this industry supply issue?
Thanks.
4/19/21       #2: Alternatives to Baltic Birch ply ...
Your vendors would be the only ones to offer an alternate. Statest Appleply was pretty nice for an alternate to BB. Solids are pretty standard but again regional availability. Hard and soft maple, solid birch, etc..
4/19/21       #3: Alternatives to Baltic Birch ply ...
Call your suppliers and ask for 5/8(16mm) Baltic. It makes better drawers. It’s typically higher quality. There is less demand for it, so there might be more sitting around.
4/22/21       #4: Alternatives to Baltic Birch ply ...
JM
We are having the same issue here in Ontario for BB. Local vendor has suggested Premcore. I havent gotten any yet, but it looks promising.....
https://www.canusawood.com/premcore
For your drawers, have you considered just switching to to pre-finished plywood and just edgebanding? Saves the finishing step and is likely less expensive.
And a final thought, just buy a dovetail drawer from Elias Woodwork in Manitoba. Its likely less costly or similar cost to building your BB drawers and frees up your time for other stuff like golf....or more work.....you choose.
