Problem with Kreg Screws
10/8/21
Pat
So, I've been using Kreg screws for 17 years without issue, but lately I've been having a problem when driving the screws. The symptom is similar to using an old bit, but I'm using a brand new long bit. Both bit and screws are Kreg brand, 1 1/4". Holes are cut using my Foreman with same settings as always.
My theory is there's a tolerance issue between the screws and the bits. It almost seems like the bit doesn't go deep enough into the screw. I plan to experiment with some older screws and bits, but in the meantime, has anyone else noticed this?
Cheers,
Pat
10/9/21       #2: Problem with Kreg Screws ...
Adam Spees
I don't like the Kreg brand screws.
We haven't used them in 20 years. QuickScrews are the go.
We only use their cabinet construction screws as well.
QuickScrews
10/9/21       #3: Problem with Kreg Screws ...
Adam Spees
The Kreg ones are probably made in China now. I only buy screws and bits made in Taiwan. Especially stainless anything.
10/9/21       #4: Problem with Kreg Screws ...
If the driver seems undersized, just bump the end on the grinding wheel and get further up the taper. Be sure to hone the burr off the bit.
10/10/21       #5: Problem with Kreg Screws ...
Pat
Actually, the driver seems oversized. It doesn't penetrate deeply enough to grab. I felt like the quality declined when they switched from the bronze colored screws years ago, but that problem seemed more about the screws breaking. I'm going to switch to another brand. Just wondering if anyone else noticed the same issue.
Thanks,
Pat
10/20/21       #6: Problem with Kreg Screws ...
Steve
Do you remember the old Kreg 8” drivers that looked like the tip was inserted into them? I believe Kreg stopped making them a couple years ago and I was having the same problem as you. I found them at Rockler a year or two back and bought 10 of them. They work much better. However I just recently received a new order of screws and haven’t dug into them yet. I’ve used Kreg screws forever, I find them very hard to get the head to twist off.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
