Delta shaper
1/13/22
lary
Trying to locate a company that rebuilds delta shaper cartridges. Seems like there was one in the DFW area.
1/14/22       #2: Delta shaper ...
Ed Austin
Yes there is a guy in Texas that works on Shaper bearings , he re-built one for me several years back , run out was better than original spec. All I could find was his email, rich.andrews@gmail.com
1/14/22       #3: Delta shaper ...
It is really not that hard. The only thing to "rebuild" is replacing two bearings which are widely available. I'll risk insulting you. All bearings have a number on them. You call a supply house give them the number and buy the bearing. One top and one bottom likely. I don't think you could spend more than $100. You might have to buy a snap ring plyer and some emery cloth.
1/14/22       #5: Delta shaper ...
lary
Ive replaced them years ago. There is a preload technique that is suppose to be used when replacing them. I am not familiar with it. Should have done it before. There is a good link on OWWM. Thought I might try someone that knows what he is doing.
1/17/22       #6: Delta shaper ...
Bruce H
I would thing the pre load would have been machined into the spindle and the location of the snap rings.
1/23/22       #7: Delta shaper ...
A&E Tool inTexas rebuilds and has parts.
That shaper is capable of accepting a cutter with a tapered threaded cap screw retaining 1/2” cutters. This means one can set up copes with a tenon of any length and still cut the cope. The tenon passes over the stub spindle. 1/2” bore, 3 wing steel cutters are readily available and can be ground to pattern for you cope needs.
