5 Piece doormaking techniques
3/30/22
Troy R Beverly
Website: http://iwswoodworking.com
I hate to ask the same old question but I have to do it.
Is there any way I can produce 5 piece doors and not have either a slight visible joint line or even worse have slight paint cracking at the glue joints from wood movement? I pride myself in my doors which is very important part of my projects. My shop is in New England with many changes in humidity and clients that don't understand the meaning of maintaining humidity levels in their home. I have quite a few clients with homes right on the ocean.
Here is my process:
Soft maple stile & rail w/ 3/8" medex or MDF rabbeted panels with 1/32" gap all 4 sides. TB-1 clamped for 24 hrs. Unclamp and stacked flat for another 24hrs. Then I remove 1/32" material off both sides of door.
This sanding I always thought would eliminate any glue shrinking in the joint. I also spray with both lacquer which is very hard and Ben Moore Advance which is oil hybrid. Should I eliminate finishing with lacquer because the oil based product would have more "flex" thus maybe reduce wood movement paint cracks?
3/30/22       #2: 5 Piece doormaking techniques ...
Wood moves.
So no.
3/30/22       #3: 5 Piece doormaking techniques ...
Worth a Try
Okay, Troy, this is pure conjecture om my part. Maybe try this idea on a sample panel, and please let us know if it happens to work.
1) Use a utility knife to cut a grove into the top part of the joints. A slight v-groove may even be better. (So, then the joints can be filled with flexible putty.)
2) Fill with high-end "flexible Bondo" that some auto-body guys use.
3) Be careful to not over-sand... Allow a thin film of the Bondo to remain and feather-out across the joint.
I believe this type of flex-Bondo does not shrink, and remains a flat, invisible seam... yet, will flex a bit to prevent cracking.
This may sound crazy and too good too be true, but it works great in my head. LOL
3/31/22       #4: 5 Piece doormaking techniques ...
Tom Gafgen
Are you sure that you are not having adhesion issues with your finish that might be magnifying the hairline cracks that are present on almost all 5 pc doors ?
I 've been spraying 20 sheen pigmented CV for many years and while after a year or so under close examination I can see most of the joints , they have never looked bad enough that I or any of my very picky clients have found offensive .
3/31/22       #5: 5 Piece doormaking techniques ...
D Brown
I always putty all the joints front and back when i un clamp to fill any tear out and as an indicator when to stop sanding. No open joints.
3/31/22       #7: 5 Piece doormaking techniques ...
Cris
1 piece HDF cut om a cnc. Problem solved. With the right programing you get square corners to.
3/31/22       #8: 5 Piece doormaking techniques ...
gary
Before we make painted 5 piece doors we explain our guarantee to the client. We guarantee them to crack at the joints and then present the mdf option and let them choose.
4/1/22       #9: 5 Piece doormaking techniques ...
cabinetmaker Member
Titebond 2
Check in dry fit stage avoid "Starving the joint" but also avoid lots of excess"
Clamp up square from the onset, yes square glue up
sand flat to 150 on wide belt, Random to 120 getting cross grains out
CV Klawlock is a good one, coat, dry out and scuff top for sand though
Top caot with stealth
Hop on over to the finish forum Lots of good advice there
4/2/22       #10: 5 Piece doormaking techniques ...
Things to think about.
-How good is your tooling?
-Are rpm & feed rates correct? Both stick and cope speeds?
-Is glue being properly applied all the way to the edges?
-Joints must be square.
-Must be clamped square
-Must have adequate clamp pressure.
-Where are you placing bumpers?
-Are you using soft close hinges?
-Are the houses climates being properly controlled?
You can't get to 100% not from a five piece. And over a long enough timeline, they will all crack eventually. I've got painted cabinets in the shop that are 4-5 years old. The temperature and humidity changes are pretty extreme. 60ºF and very low humidity in the winter. 90º+ in the summer, 90%+ humidity. Very few of those doors have cracks in the finish.
4/2/22       #11: 5 Piece doormaking techniques ...
Matt Calnen
Karl had a lot of good points. I would add that for my absolute best paint grade work, I switch to quarter sawn hard maple. It mills harder than soft maple, but moves less and paints better.
If your going to leave glued up for 24 hours, you might as well use epoxy. That should also help with the glue line. I learned on wood web that Titebond 2 was a bad choice for glue lines showing through sprayed paint finishes. Can’t recall the exact reason, but I did see a difference, and usually just use TB 1 now.
I do think you will have less of an issue with a softer paint, so it can flex a bit.
5/9/22       #12: 5 Piece doormaking techniques ...
Brent Member
Website: http://www.parkhillwoodcraft.ca
I have to be honest, I have had 95% success in not cracking 5-piece doors and the frame joints - my shop is wood heat in the winter w/ 15% humidity, and probably 80-85F in the summer with maybe 50% humidy. I use a Sherwin Williams water primer and MLC Arroyo or Augalente topcoats. The frame to panel joint was a nightmare until I went to custom tooling with a "paint notch" in the frame. Sure this adds a sight line, but way better than a finish crack line. Just be honest with your client - it is what it is. Solid mdf doors are, IMO, about the only way around the issue of wood moving.
Also, just an opinion: try and move away from the BM Advance paint - there are so many better options out there in a waterborne system.
5/9/22       #13: 5 Piece doormaking techniques ...
Jim
Titebond II sets with a soft glue joint
TB Original sets hard and doesn't telegraph thru the finish
I have good luck with joints using automotive 3M glazing to fill the odd hairline prior to sanding with the widebelt
I use 1/4 or 5/8 mdf panels in paint grade
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
