Inset doors
5/25/22
Chris
On building a cabinet with inset doors do you put a 1/8” round over on your door edges or just break the sharp corners with a piece of sand paper?
5/25/22       #2: Inset doors ...
Leo G
Hard sand. I usually slow my Mirka Ceros down 3 bumps and do 3 quick passes -22, 45, +22 degrees and then two passes with 150 grit. I would guess it ends up at about 1/32"R
5/25/22       #3: Inset doors ...
Just a quick hand sanding to just break the edge. A full radius will show as a shadow and make a nice gap look huge.
5/25/22       #4: Inset doors ...
Chris
That was my thought to thanks for the input
5/26/22       #5: Inset doors ...
We break the edges for finishing. 150 grit with a block. The corners we round over a bit. It prevents the doors from damaging other stuff.
5/26/22       #6: Inset doors ...
Chris
Sounds good that’s what I will do thanks
6/12/22       #7: Inset doors ...
Tom Gafgen
The Fastbreak from FastCap does a nice job for this .
